Saltar al contenido principal
The HP Envy 17-J013CL is Hewlett Packard's 2012 version of the Envy series. 1600x900 resolution on a 17.3-inch HD display.
Preguntas 5 Ver todo
scrws broke out the casing holding the hinges
I need a repair manual to replace the hinges. Somehow the screws under the rubber feet on the left no longer hold, plastic particles have broken out. Tighten the screw, now it is no longer pure and there are plastic parts eroded. When I open the laptop, the case gapes, what can I do? Do I have to swap the hinge or possibly parts of the housing? Which parts do I have to disassemble to get to the hinge? Please post the instructions for removing the necessary parts.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Solución Elegida
Hi @cyppo ,
Here’s a link to the service manual for your laptop, taken from this webpage
Scroll to p.72 to view the necessary pre-requisite steps and then the procedure to remove the hinges and top cover (also known as the palmrest).
On p.21, item #2, you’ll find the part number(s) for the top cover.
Search online by typing the part number only (appropriate to your particular model variant), in the search box of your browser to get results for suppliers of the part
Fue útil esta respuesta?
Puntuación 2
Respuesta Más Útil
You will need to replace the entire palm rest. I tried doing a quick search and could only find parts for the HP Envy 15, so you will have to look around a bit more. Make sure you get the 17.3” model.
Puntuación 3
I have found that the hinge tightens itself up when opening and closing so i got a socket on the nut and loosened the nut off so the hinge was much looser and stopped the plastic from breaking it is a flaw as the more you open and close it the more it tightens up !!!
you have to open up the hinge plastic and get a socket in there to turn it to loosen it as the image shows the nut
Puntuación 0
Añadir tu respuesta
Michael Cyran estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 2,376
