Saltar al contenido principal
Procesador de 1.4GHz o 1.6GHz, SSD de 64GB o 128GB.
Preguntas 160 Ver todo
MacBook will not charge.
I have tried a new charger, but it’s the same. Sometimes I get a solid Orange light, sometimes green. It stays on 0 percent, and doesn’t move.
When I look at the battery statistics it says that the capacity is 5246 and 627 cycles.
Any ideas?
Update (12/19/2018)
The light is now green but still no charge. Its solid green.
UPDATE (07/19)
Sorry to resurect this but I’ve only just got around to a new I/O Board attempt.
Was strange as before it was always on 0 - 1 percent and not charging, replaced the I/O board and now its on 20 odd percent, still not charging, and battery is being used but going down.
Any other ideas as I’ve tried a new I/O Board and 2 new batteries now.
Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
11 comentarios
Lets take a deep look here run this gem of an app CoconutBattery take a snapshot of the main window with the MagSafe charger connected and a second snapshot with it removed. Paste them here for us to see Agregar imágenes a una pregunta existente
- de
try a different dc in board
- de
What’s that involve, is it doable myself?
- de
the i/o board guide that trevor posted
- de
Did you have a liquid spill at some point? I'm thinking the charging logic within the logic board is damaged.
- de
Mostrar 6 comentarios más
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Two possibilities:
Most likely possibility: bad battery
MacBook Air 11" Late 2010 Battery Replacement
MacBook Air 11" (Late 2010) Battery
Less likely possibility: I/O board
MacBook Air 11" Late 2010 I/O Board Replacement
MacBook Air 11" (Late 2010) I/O Board
Imagen de MacBook Air 11" (Late 2010) I/O Board
Producto
$74.99
Imagen de MacBook Air 11" (Late 2010) Battery
Producto
$79.99
Imagen de MacBook Air 11" Late 2010 Battery
Guía
Dificultad:
Moderado
15 minutes
Imagen de MacBook Air 11" Late 2010 I/O Board
Guía
Dificultad:
Moderado
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
andy hawkins estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 189
