Saltar al contenido principal
Hasta -20 % en herramientas selectas
Envío gratis en pedidos nacionales de $75 o más
Impresora láser fabricada por HP. Utiliza el cartucho de tóner 12A, que genera 2.000 páginas con una cobertura del 5 %. Clasificada en 15 PPM.
Paper feed processing problem
My HP Laser Jet 1012 printer successfully prints a page, but will not feed through the printer entirely and a second page becomes jammed in the feed mechanism
Es esta una buena pregunta?
Puntuación 2
1 comentario
I was having the same problem and the iFixit diagnosis, i.e., that there was a problem with the pickup roller was correct! Here is a guide to cleaning or replacing your pickup roller from the HP web site: https://support.hp.com/us-en/document/c0.... My problem was solved just by removing and cleaning it.
- de Compartir
Agregar un comentario
2 Respuestas
Solución Elegida
I believe there are maintenance kits for these models which are usually expensive, but more times than not it’s the pickup roller. Try another toner as well. I have seen in certain printer models where the toner can cause jams.
Fue útil esta respuesta?
Puntuación 2
The User Manual (which you can get online) recommends:
  • Cleaning the pickup roller with a lint-free cloth and rubbing alcohol. Just tried that and it enabled my printer to grab 3 pages one after the other (instead of jamming after just one).
  • Alternatively, replacing the pickup roller. I see you can order some on Ali Express. Haven't tried that yet.
In the meantime, a temporary solution is to stand by the printer while it prints and manually load one page at a time.
Puntuación 0
1 comentario:
I replaced pickup roller $25 and still have same problem. Now thinking it's sensors, in which case, probably bye-bye printer. Otherwise, this printer has been the best tech investment ever in terms of stability, function and reliability, so missing in other gear.
- de Compartir
Añadir tu respuesta
Ellen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 53
Todo El Tiempo: 2,764
