Wii will not turn on
Hello,
My Wii will not turn on.
I plug the A/C adapter in the power outlet and check with a multimeter : I get around 12V.
Now I plug the A/C adapter in the Wii and the light doesn’t turn red. If I unplug the power adapter and check the voltage, I get 0V. If I let the power adapter sit disconnected for 2 minutes to reset it and try again, it goes back to 12V, and back to 0V as soon as I plug the Wii.
Do you know what could cause this issue?
Es esta una buena pregunta?
Hi @alamaree
Most probably inside Wii there is some shorts.
as a precaution the power adapter will shut off to prevent further damage to both.
you will need to access to the mainboard section to inspect the components
- de Augustine
What do we do from there if the circuitry within the wii is a problem?
- de Hunson Abadeer
