Saltar al contenido principal
Guías de reparación y soporte para la serie WF361BVBBEWR, incluida la A1. A 3.6 pies cúbicos. Lavadora de carga frontal de alta eficiencia de 8 pies de capacidad con calentador de agua interno.
Preguntas 18 Ver todo
Why does the machine fill up above normal level and then give a nf err
The machine fills up fast and above ordinary level and still it wont goto next cycle and drain, displaying a nf error which stands for a water filling failure… it does fill. Even over fill. I even have leaks due to water level. I have to power off the machine and force the spinning cycle for the water to drain.
When i go into forced spin cycle, the water drains easily but the cycle seems stuck. I have to stop the machine, shut down, power on again and go into the forced spin cycle again, for it to work and complete.
can someone help?
Es esta una buena pregunta?
Puntuación 0
1 comentario
Hey,
i got the same problem! valve changed, pressure switch changed… what else can i do?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Hi,
It may be that the washer water level pressure switch is faulty.
Here’s a link to the parts for your machine. Click on the Drum Assembly parts diagram to view the location for part #5, washer water level pressure switch.
It may also be that the water inlet valve is sticking open.
The following is regarding an nf error code for your model washing machine: (scroll down to “nf or nf1” entry in the error code drop down box on the page in the link above)
If water flows okay, check the inlet screens on the water inlet valve assembly. If the screens are clogged, replace the water inlet valve assembly rather than cleaning the screens. Cleaning could allow debris to enter the valves, resulting in the valves sticking open and causing a flood
Click on the Drawer Housing parts diagram link to view the location of the water inlet valve (Part #2 in the diagram)
Here’s a link to a guide how to replace the water inlet valve.
Hopefully this is of some help
Fue útil esta respuesta?
Puntuación 1
6 comentarios:
Thanks so much. The air tube was disconnected from the pressure switch. Big big thanks
- de
I have the same problem have replaced both the switch and valve just keeps filling with water
- de
@Vickie ,
Did you check the air tube connected to the switch is OK, you didn't say?
- de
How can water intake valve be replaced
- de
Who can I contact to replace valve
- de
Mostrar 1 comentario más
Respuesta Más Útil
Cause 1
Water Inlet Valve
Try shutting off power to the washer while the machine is filling with water. If the washer continues to fill with water even when it is not getting power, this indicates that the water inlet valve is defective. If the water inlet valve is defective, replace it.
Cause 2
Pressure Switch
The pressure switch shuts off power to the water inlet valve when the proper water level is reached. If the pressure switch fails, the water inlet valve will continue to fill the washer tub with water, causing the washer to overflow. Before replacing the pressure switch, check the air tube to the pressure switch to ensure that it is clear of debris and is not leaking.
Cause 3
Low Water Pressure from House Supply
The water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the water inlet valve does not get enough pressure, the valve may not close fully after the power is shut off. As a result, water can leak into the washer and cause it to overflow. Check the water pressure to determine if it is sufficient.
Puntuación 3
1 comentario:
Thanks so much. The air tube to the pressure switch was disconnected... problem solved fortunately with your precious help.
Thank you so much... i wish samsung would be as efficient and honest... its been 3 weeks that i am waiting for them...
Thanks again
- de
Añadir tu respuesta
louping67 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 34
Ultimos 30 días: 136
Todo El Tiempo: 10,255
