Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to replace lcd screen
I actually have the asus q524u which I believe is the Best Buy exclusive model? This is the only asus laptop I’ve found with the same hinge/case setup and is probably very similar.
I have some cracks on my lcd screen behind the digitizer. The digitizer glass is perfect and touch works perfect.
I have ordered a new screen that should be here in two days but I can’t seem to find any tutorials on how to disassemble the bezel and screen, I’d hate to have to guess and break clips off or worse.
If anybody has any experience please advise! Thanks!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
https://www.youtube.com/watch?v=ynIQwPPD...
It Is not the same exact model in which I understand but it completely the same concept and should help you fine if not give you a great idea on what to do.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thanks, I’ve watched that and many other similar as well. My concern is most of videos I watch there are hidden screws somewhere holding the bezel in place. I don’t see any so I may just pry mine
- de
You will be ok man! Good luck
- de
Añadir tu respuesta
cbrackett90 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 33
Todo El Tiempo: 2,725
