Sharp aquos LC-32CHG6021K TV
My Sharp aquos LC-32CHG6021K TV just updated and now everything is upside down how do I flip it back
Es esta una buena pregunta?
I have the same problem. The Aquos smart TV just updated and the image turned upside. I called the technical support unit of sharp in the UK. Problem solved. Solution: press menu button on the remote; urgently press 1147; select item 7(panel), press item 9(Mirrow). Done. Good luck!
Fue útil esta respuesta?
This worked for me thank you so much
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 3,211
10 comentarios
Hi @goodhart ,
Did you try the "reset" option found in the TVs "setup" menu? You didn't say.
Be aware if you reset the TV you'll have to scan for the channels again as they will be cleared from the TV.
- de jayeff
Did mine 30 mins ago as well same thing happened any luck yet ?
- de cjas32
yeah my tv has done the same thing after update,and iv been though every setting this morning and still wont go back to normal
- de joe shields
Hi @cjas32,
You may have to contact Sharp about this.
3 different TVs exhibiting the same problem after performing an update is too coincidental to my mind
- de jayeff
Sounds like something on their end within the update hence why multiple people have had the problem
- de cjas32
Mostrar 5 comentarios más
