phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
Es esta una buena pregunta?
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
Fue útil esta respuesta?
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
To take a look on battery terminal if a well connected second to check life of battery
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
Phone is not power on and showing logo
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 24
Todo El Tiempo: 3,620
2 comentarios
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
- de gharib mahmoud
Sir, my mobile battery is very weak, what should I do to get it fixed?
- de Mustafa Kamal
