Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Dodge Challenger Concept se presentó en el Salón del Automóvil de Detroit de 2006 y fue un adelanto de la 4ª generación del Dodge Challenger, cuya producción comenzó en 2008. Muchos elementos de diseño del Dodge Challenger Concept se adaptaron del Dodge Challenger R/T de 1970.
Tach sitting below zero
just bought a 2010 Challenger R/T last week. I am in the process of installing my radio from my old car into this one. I pulled the instrument cluster to run the microphone wire behind it. Long story short... I went to put it back together and noticed that the gauges were sitting below all the markings. I got everything reset. But now the tach is sitting below zero rpms even when i turn the key on. I have tried resetting the cluster with the trip button. It doesn't help, i manually rest it back to zero with the key on. I turn the key back off and it stays good for about 5 minutes then it falls back below zero and doesn't come back up when i turn the key back on. Need some help on how to get it to sit right. This is the last thing i have left before i can finish putting the car back together.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Did you check all your fuses?
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I just seen the date that you posted that. what was the problem?
- de
Añadir tu respuesta
Joshua Johnson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 354
