Saltar al contenido principal
Lanzado en noviembre de 2014, el HP Stream 13 es un portátil delgado con Windows® de un solo cuerpo con un precio para competir con los Chromebooks y el MacBook Air de nivel de entrada.
Help ASAP! Hard Drive Upgrade Via WifiPort!
Question and I need help!
I have an HP Stream and the hard drive is only 32gb and soldered via EMMC and need to upgrade it! I have the HP Stream 14 series this year I believe!
Now, I saw an existing forum regarding this laptop here: Desmontaje de HP Stream 13 para actualizar SSD mini PCIe
However, I do not get answers and I believe the user that said using MSata hard drives will work won't answer anymore! I am wondering if this has been confirmed working and if anyone has tried it and was successful! I have the wifi card here I took out: https://ibb.co/hANX98 and not sure what ssd to buy that will fit the existing port to try out!
Any assistance would greatly be appreciated!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Your WiFi board uses a PCI Express Mini Card interface. So it’s conceivable a a short mSATA board would physically fit. The only risk is if the system would recognize it.
mSATA SSD (mSATA solid-state drive)
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Daniel Ringuette estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 470
