Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado el 25 de septiembre de 2015. Modelo A1687 / A1634. La Reparación de este dispositivo es similar a las generaciones anteriores, requiriendo destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16, 64 o 128 GB / Silver, Gold, Space Grey o Rose Gold.
Getting hot during boot
Hi I have a 6s plus getting hot during boot right at cpu and pmic I was wondering if a screen could do this if I boot without screen it's normal temp with screen it will burn your finger as soon as boots it cools but I'm unsure if it's a short on pp gpu line the reading is 0.006 on that line qwick battery drain as well as wrecking battery's within a month of replacing
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
This might be a dumb question but have you tried the screen with the front camera and/or home button unplugged?
Either of those being faulty (causing short circuit) will cause the phone to heat up at the screen connector and CPU area.
I had a client come today that had a friend recently replaced their iPhone 6s plus screen. Phone was heating up a lot due to a short circuit and not turning on.
Turns out it was the front camera cable being partially ripped and plugged in causing a short.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Yes I have I think it might be a short in the lcd cable but it's getting hot right over cpu not the cables very confused and I don't have another screen to test it
- de
Il test soon if it's cpu or pmic getting hot
- de
In my opinion it doesn't make much sense to get concerned about cpu or pmic if the short shows up only when the screen is connected. Unless I misunderstood your description first thing to do would be to try out a replacement screen after checking carefully that lcd and logic board connectors are in perfect conditions.
- de
Añadir tu respuesta
dylanrichter44 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 101
