My tv was broken by a baby throwing something at it
A baby threw something at my tv n now it has horizontal lines running threw it
Es esta una buena pregunta?
@rc222 without seeing it and only going by your description, this sounds like a broken LCD display. Post an iame of what your screen shows you. That way we can see what you see. Use this guide Agregar imágenes a una pregunta existente for that.
If it is the LCD screen it will be difficult and expensive to try to replace it. those screens are ‘‘‘not’’’ readily available. you may have to take a look at the back of the LCD panel and check the manufactures label. With the right number for the panel you can try an online search and see what you can find.
Fue útil esta respuesta?
Help I accidentally broke my boyfriend's T.V can it be fixed or am I totally &&^&@@?
Hi @bunnie
If the screen is cracked it will be difficult to find a replacement screen, if at all.
If you do happen to find one (see Most Helpful Answer above how) don't be surprised that it may cost nearly half as much as a new TV.
The best option is to advertise the TV as "faulty screen, good for parts" to try and recoup some of the cost towards a new TV.
Working TV boards are always in demand.
Need help my screen got yellow purple red lines going horizontally n is black where I threw my mouse due to raging is it fixable
Any cracks in the screen means that the screen will have to be replaced.
Ultimas 24 horas: 4
Ultimos 7 días: 13
Ultimos 30 días: 52
Todo El Tiempo: 692
