Saltar al contenido principal
Modelo A1278 /Procesador 2.4 o 2.66 GHz Core 2 Duo de mediados de 2010
Preguntas 795 Ver todo
How to run logic board out of laptop?
I have a broken logic that appreantly powers on. However I don’t have a complete laptop to put the logic board in. I tried plugging a MagSafe up and display port to the board and a hard drive with the connector. When I short the pins up the board powers on no display then the fans go max. I just found out that the fans will go max if no trackpad is connected which it isn’t. Is there anything else I need connected to the board to get it running.
Es esta una buena pregunta?
Puntuación 0
1 comentario
What are you trying to do here? You really need the rest of the system to make this work.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
No need to bother about the fans..if screen doesn't light up at boot you either have a no image or a no backlight issue. However you should see the question mark folder shining a torch light to screen if it's just a backlight fault. If you don't have backlight or an image, matter is complicated enough in any case..if you're not a pro it would take you days or more to figure out what's faulty..
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Louis Greenleaf estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 74
