Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El HP Envy dv7 es un portátil con Windows 8 que cuenta con una pantalla de 17,3 pulgadas.
Boot device not found
At start screen boot device not found is showing. I am unable to get into bios and uefi is not showing component testing what should I try next?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi flee865
had you tried this?
what is your current OS?
Turn off the computer.
Hold down the windows key + b and power on the laptop without letting go.
Here's the magic: while holding down windows key + b, then press F2.
The laptop will enter BIOS recovery mode, and you should be all set from there.
Reference:
https://h30434.www3.hp.com/t5/Notebook-B...
When you had successfully entered the UEFI / BIOS, check if your hard disk is detected,
consider running diagnostics on the HDD, also to ensure if the bios boot setting is correctly configured, e.g. secure boot, uefi.
else if it is not detected, try reseating the HDD and repeat the process.
Sustitución del disco duro del HP Envy dv7
or else get another HDD to test, if it is detected, consider getting a replacement . SSD is recommended.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
It says bios recovery not found I only tried the first step
- de
Hi flee865, had you tried with other keys? e.g.
Esc,F9,F10,F1,F2 etc
On the computer and press F10 fast.
you might also need to check in hp for updated bios for update or recovery.
https://www.youtube.com/watch?v=zjAZ0DTX...
- de
Añadir tu respuesta
flee865 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 1,522
