Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Grand Prix se actualizó para 2004 en una versión revisada de la plataforma GM W y se presentó en el Chicago International Auto Show 2002 el 7 de febrero de 2002 como el Grand Prix G-Force Concept.
Multiple System Warning lights on
The transaction control, service break system and service abs system warning came on all at once in my 04 pontiac grand prix 3.8 . I have all new breaks all the way around. And replaced the right rear wheel bearing abs hub per the scan results. The lights will go off for awhile then come back on. Battery and Alternator were checked and they are in perfect working order
Es esta una buena pregunta?
Puntuación 0
1 comentario
The Gran Prix was the biggest piece of garbage GM ever made........And the answers you get from these sites are all guess work
- de
Agregar un comentario
3 Respuestas
Solución Elegida
@vulkus has given you a good start(which he should have put into an answer so we can vote for it ) . You mentioned service break system light was on . when you changed the breaks did you open the system to air if so you may need to bleed the system are the brakes spongy or do you need to pump them to get stopped . Or had brake fluid been added to the system then when you put new brake pads on did it overfill the system as less fluid is needed with new pads . Check fluid levels regardless . If you have open tone rings check them for mud and road grim . if there sealed rings then check the wheel bearings seals for leaks . if grease is coming out dirt can get in and plug the tone ring . Finally does the traction control cause the car to shudder in sharp turns or or send vibration through the steering on long slow curves? let us know . Hope this helps
Fue útil esta respuesta?
Puntuación 4
4 comentarios:
Everything has been done properly. Scan shows no errors since I replaced the rear abs hub assembly. But warning keeps coming back intermittently
- de
Oh and everything works great. Breaks respond perfectly. No control issues. At this point I'm just gonna replace the 3 remaining will bearing hubs/sensor's (they are one unit) and see what happens because everything else has been done. After all it can't hurt the cars 14 years old. Thanks for trying :)
- de
Before you go buying new hubs, try to replicate the problem on other wheel sensors. Swap the left rear wheel sensor with the right rear wheel sensor and see what happens. It could be a wiring issue. Also get brake cleaner and spray the bejesus out of the tone rings, while rotating the wheel. (on jack stands).
- de
Is the battery good in the key fob this can keep the car from starting and cause all kinds of electrical things to happen
- de
You will need to check if there is a fault with your front and rear abs wheel sensors. Hook it up to a scanner, reset all the codes. Drive it and see what resets.
Check all your wheel sensors by removing and visually inspecting the units. Wipe any grime or grease off them then replace. Check all the ABS sensor cables make sure they aren't broken or damaged in any way. Replace any suspect ones.
Last of all check all your fuses.
Puntuación 2
1 comentario:
Thank you for your reply
I already did that and no error codes when I scan it since rear hub/abs replaced. But still getting warning. :)
- de
I have the same problem with a 2004 Grand Prix. ABS, Brake and Traction warning lights on dash and in the warning display. I took the battery out for a day trying to reset it but it didn’t help. It started immediately after the previous owner had the transmission replaced so I suspect it was something that the shop did. I hope you can figure it out and let me know if you do. I was given the car so I don’t want to put a bunch into it. I may take it to the dealer and see if they can reset it.
Puntuación 0
Añadir tu respuesta
Robyn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 51
Todo El Tiempo: 8,339
