Saltar al contenido principal
Unibody de aluminio de 13", procesador Core 2 Duo de 2.0 o 2.4 GHz.
Preguntas 574 Ver todo
How can I configure this late 2008 machine to run High Sierra?
I am currently running my Late 2008 MacBook on the El Capitan OS
Apple says that my machine is too old to update the OS to High Sierra but my problem is that Logic X version 10.4 will not run on El Capitan but needs Sierra or High Sierra to run
I am running Logic X 10.3 on the machine at the moment but this looks like I will not be able to have any more updates of Logic
Is there anything I can do - apart from buy a new machine of course?
Thanks
Graham
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
There is no EFI update that is available for a 2008 that supports the High Sierra OS and new File Systems.
The dosdude patcher only works on 2008+ Pros, and 2009+ non-Pros.
http://dosdude1.com/highsierra/
Fue útil esta respuesta?
Puntuación 3
1 comentario:
@grahammartin - Check your model ID if you have MacBook 5,1 then you're in luck! As the patcher @avanteguarde lists here will allow you to upgrade with High Sierra.
But that in its self may not help you ;-{
RAM and storage limits of your system will effect your ability to run anything big or long, besides the lag your older CPU will have running the app (Logic Pro X).
- de
Añadir tu respuesta
Graham Martin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 500
