Saltar al contenido principal
Teclado inalámbrico de cuarta generación fabricado por Apple. Lanzado en octubre de 2015. Modelo A1644.
Magic Keyboard 2 can not connect it via Bluetooth
My Magic Keyboard 2 can not connected via bluetooth, can only connected via usb, it just like dead totally after unplug usb cable.
Before this happened, I were cleaning it, and claped it a little bit, then it can not connected via bluetooth, usb is fine.
I wonder if the wire between battery and board is disconnected or something.
Is anyone knows what is going on ? Do I need to tear it down ?
Es esta una buena pregunta?
Puntuación 3
3 comentarios
Did you clean it with a sanitized wipe? I've seen them cause liquid damage of keyboards.
- de
No, no water inside
- de
I have the same problem, I did not clean the keyboard, but bluetooth connection stops working, only works via USB
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @kylebing ,
You may have 'bounced' the battery flex cable plug out of the connector on the pcb, when you 'clapped' it.
Here is a link to the ifixit Desmontaje del Magic Keyboard guide.
Scroll down to Step.6 and hold your mouse pointer over the 3rd image to view the connector.
The guide is for the Magic Keyboard but hopefully it will be similar to your keyboard and this will still be of some help to you as you will have to open your keyboard to ascertain what the problem actually is.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks, I have opened it and didn't find the problem is. I think it is caused by the bad battery.
- de
Añadir tu respuesta
Kyle Bing estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 7,584
