Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La máquina de coser de puntada de cadeneta Singer EZ-Stitch está diseñada para ayudar a los principiantes a crear sus propios proyectos divertidos y creativos. Se puede utilizar para ensamblar manualidades, ropa, almohadas, accesorios y más.
Thread gets stuck in machine
My singer machine has thread that gets tangled in the machine. I have gotten it out following the book, but it happens again every time I try to sew. I can’t use it at all. I bought it at least 10 years ago & didn’t use it for the first couple years, then we moved. I tried using it & had that problem immediately. I asked my sewing teacher & she told me it would cost more than the machine is worth to fix it. I can’t afford to buy a new one. I picked it up for like $115 at Target. Not the highest model. I also followed instructions for threading.
I have a different model than chosen. It’s a much better machine than this.
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Its not the machine pictured. I have a full size machine.
- de
@magecat any idea what model your machine is?
- de
It’s a much better machine than the one pictured. It has several stitches. There is a bobbin beneath the plate, none on top.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Is yours a chain stitch machine like the one pictured, or does it have a bobbin beneath the plate as well as a bobbin in the top?
I wrote up all I know about sewing machines at https://wiki.restarters.net/Sewing_machi... - perhaps the tension is wrong, or the needle is bent, or the timing is out.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
ladycerridwyn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 1,763
