I used 12v adaptor instead of 6v, now it has stopped working.
Hi,
I used wrong 12v adapter instead of 6v in bp monitor, now it has stopped working. What to do now?
Es esta una buena pregunta?
Hi,
Hi,
You most probably have a damaged voltage regulator and / or other input supply voltage components on the monitor's control board.
You will have to open it up and inspect it for any obvious damage.
Post some close up pictures of any damaged areas on the control board (hopefully it will be obvious but perhaps it won't be) and maybe someone here will be able to help.
Here's how to do it.
Fue útil esta respuesta?
It’s possible it used battery power during the time it worked and due to not getting a charge through the 6v power supply, it’s now drained. Try getting the right power supply and try again.
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 2,237
1 comentario
How can I fix my blood pressure monitor
- de terry skinner
