Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guía de reparación y soporte para la Samsung CLX-3175FN, una impresora láser a color multifuncional que también funciona como fax y copiadora.
Toner Waste Bin Error message
I removed and replaced the Toner waste Bin and now I get an error message to "Replace/Install Toner Waste Bin." How can I clear this error?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Check it's seated properly.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
This made no difference.
- de
Empty it, rinse it with water, dry it out well and refit it
- de
Respuesta Más Útil
Please check whether the clear plastic "windows" in the bottle side are clean. The system "sees" the toner level through those "windows". Try and keep them clean (otherwise the system will think the bottle is full of waste toner). Take care NOT to blow, you would spill toner everywhere! Gently tapping the bottle on a hard surface is usually sufficient.
Puntuación 1
1 comentario:
You may need to clean the inside, I've used a few drops of laundry detergent and let it sit for around 10 minutes then washed it out in the bathtub and poured a bit of 99% rubbing alcohol, let that sit, washed that out, put it back in, and all good.
- de
Añadir tu respuesta
Kerry Ross estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 1,355
