Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guía de reparación e información de resolución de problemas para el ratón inalámbrico de Apple con soporte multi-touch. Número de modelo A1657 o A3204.
Cannot select with MM2.
Cannot select with MM2. I can move cursor but cannot click. Also disables my ability to select on trackpad. If I turn off MM2, trackpad functions normally.
Es esta una buena pregunta?
Puntuación 3
1 comentario
Hello!
I had the same problem with the MM2. I could move the pointer but it did not go right or left click. Have a reset of the mouse performed, tried on another Mac.
Nothing worked!
Then I disassembled the mouse according to ifixit instructions and, as in step 7, disconnected and reconnected the data cable.
And the mouse works again like the first day!
I hope I can help some users with the info, because I found nothing on the Internet.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Try going to system preferences > trackpad > see if "tap to click" box is checked.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thanks, I can select with the trackpad as long as the Apple mouse is disconnected. I am using a cheap external mouse and getting by. I think the Apple mouse is my problem. At $75 I'm going to have to make do with the off-brand mouse. It has made me become more proficient with the trackpad.
- de
Well. get a used one, I just bought 4 for $45 https://www.ebay.com/usr/tricomputersolu...
- de
Añadir tu respuesta
James M McMurtry estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 26
Todo El Tiempo: 1,509
