no backlight no picture and sound come
Hi,
I have samsung UA55ES8000 tv and it was suddenly stop working. Cuz no backlight & no picture but sound still working. When i disconnect the LVDS cabel from T-CON board then backlight turns on.why is that? Please answer me
this is what i have done before it went black screen
Es esta una buena pregunta?
5 comentarios
hey, did you find the solution? having same issue
- de עמי לווינשטיין
yes.. it was T-CON board issue. i replace the T-CON board.
- de Dulan Wijesundara
Which tcon board was it? Pic please to show
- de Emma Champagne
@Emma Champagne
TVs only have one tcon board. The tcon board is the board that connects to the screen.
Depending on your model it may look like the one above with the red and yellow arrows on it showing the cables that connect to the screen.
Usually you can tell which one the tcon board is because the mainboard connects to it and it connects to the screen i.e. mainboard > cable > tcon board> cable(s) > screen
- de jayeff
Had 2 vertical lines. Replaced with a new T-Con board. Restyle…No picture but had sound. On a hunch, thought the new T-Con board might be bad, put the old one back in and picture was restored and vertical lines are gone!
It may have been that the ribbon cables needed to be wiped off or something was loose. TV is working fine and it beats having to purchase a new one$$$
- de Diana
