Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías para la versión Wi-Fi del iPad Mini 4: modelo A1538. Anunciado el 9 de septiembre de 2015, el iPad Mini 4 es el sucesor del iPad Mini 3.
Question about home button replacement
So, I have this iPad mini 4 which the Touch ID works, but the home button doesn’t. Is there a way to just replace the home button clicking part?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Have you recently replaced the screen or have had it opened before the problem?
Yes, you can replace the home button to get it working again or you can open it to make sure it is making proper contact with the pads that make the physical connection. Here is a post that describes the issue a bit better:
iPad Mini Home Button Not Working After Digitizer Replacement
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Yes, I have done a screen replacement before. Well during that time, a rubber thing was thorn apart and I just left it in my drawer. How would I go about just replacing the home button part instead of the whole Touch ID + home button? Would the Touch ID still work?
- de
Añadir tu respuesta
Koguma6969 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 25
Ultimos 30 días: 47
Todo El Tiempo: 1,923
