No sound from the device at all.
When I turn it on or off, it doesn’t make any sound. The speaker worked just fine about a week ago and I haven’t used it since then. I have factory reset it and updated it. It does connect to my phone but there still isn’t any sound.
Es esta una buena pregunta?
8 comentarios
I bought The omni ultra got to listen to it for one night and then no one from altec. Would even answer me back or even call me I played a lot for the device and I'm sorry but ill never buy anything with the altec name on it again
- de Alan
I just got the megaboom 3 today and I can't get it to make any noise after it initially made noise. It won't make any sounds when I turn it on or off and I can't get it to reset. Please help. I've had the UE megaboom original from the beginning and this one appears to be a lot more complicated.
- de malvocarmichael76
Same problem here in my UE BOOM 2 and getting no answers
- de facundo rojas
Same problem with UE boom
- de Haileyk
Gday guys, had exactly this problem, would start playing fine and then randomly stop making sound whilst being connected. Opening other apps than the one playing music would also do it. Made no start up or shutdown sounds either.
The way I fixed it was to turn it off for a few hours, charge it up if need be. Forget the boom2 on your device, then power on the boom 2. After letting it rest and charging it, it should once again make the startup noise. Now you can successfully do a hard reset by holding down the volume “down” button and the power button until it makes a new noise, takes about 6-10 seconds. I
Add your boom 2 to your device again, update the firmware with the official app, you should be good as new
I had no luck doing a hard reset while there was no sound coming out of the unit, you have to make sure it can produce the startup sound before trying.
Edit, this worked great for literally only 6 hours, when it stopped playing all sound again and I needed a hard reset. Your guess is as good as mine
- de Jezza
Mostrar 3 comentarios más
