Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Guías de reparación e información para los mandos Joy-Con de la Nintendo Switch.
Replaced joy-con shell; bungled joystick?
I did a shell replacement on my whole Switch, including the body and both joy-cons. Everything went great except for the right joy-con: I must have screwed up the joystick because now it’s permanently sending “joystick right” anytime it’s connected to my unit. The joystick itself looks just fine, it doesn’t look bent. The only thing I can think of is maybe I screwed up the ribbon cable when I plugged it back into the joy-con circuit board.
Has this happened to anybody else? If so, is there a fix? If not, is there a place I can buy a new joystick assembly for the right joy-con?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I have a similar issue - try lifting the rubber flap that covers the Joystick guts (just under the stick). Then blast some compressed air into here and move stick blast, move stick, blast. See if that helps. Then run the analogue stick configuration from settings.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
How did you get the rubber cap back on? It won't fit in for me.
- de Compartir
You list it back with two pins it will flap and stay back if done right. A little fiddly but if not you hold while someone else sprays
- de Compartir
Añadir tu respuesta
Ben Kreeger estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 40
Todo El Tiempo: 2,947
