Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
MDR-ZX100 Auriculares estéreo de la serie ZX fabricados por Sony.
Left speaker is not working
My Headphones Sony-Mdr zx-100.
Left speaker is not working. I opened it wires are pretty fine. but,Speaker is not working. I checked the speaker poles(+ve &-ve) with multimeter,there is no continuity in poles. I think the speaker winding is cut off. Can anyone fix this, please help!
Here is link: https://drive.google.com/folderview?id=0...
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
@ramukris how did you test your speaker? What settings did you use? Where did you check?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@ramukris you need to check your wires with a multimeter in ohm settings. Then touch the contact at the connector that you plug in with one probe and the other probe on your speaker. If the wires are okay then your needle will move. If the needle does not move you have either a loose wire on the connector or a broken wire. It is uncommon for the windings to shorten out in the speaker itself. Polarity is not important while checking for continuity.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
what about the right speaker, I accidently dropped my headphones and the right speaker came off but the wire is still attached what should I do?
- de
Añadir tu respuesta
Ramu Kris estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 873
