replace blower motor resistor
how to replace blower motor resistor in 1999 dodge dakota
Es esta una buena pregunta?
wayne rients here is the way the manual describes it:
REMOVAL - BLOWER MOTOR RESISTOR
(1) Disconnect and isolate the battery negative cable.
(2) From the passenger foot well area, remove the two hex screws used to secure the blower motor resistor.
(3) Unplug the front blower motor resistor from the wire harness connector.
(4) Pull the front blower motor resistor and its wire harness out of the plenum panel and through the cowl plenum access hole far enough to access the wire harness connector.
(5) Remove the front blower motor resistor from the cowl plenum.
INSTALLATION
(1) Plug the blower motor resistor into the wire harness connector.
(2) Install the blower motor resistor to the cowl plenum panel by feeding the resistor and wire harness back through the cowl plenum access hole.
(3) Install and tighten the two screws that secure the resistor to the HVAC unit. Tighten the screws to
2.2 N·m (20 in. lbs.).
(4) Connect the battery negative cable.
Here is that chapter from the manual Dakota HVAC Sometimes you may have to loosen the dash to get to it.
Fue útil esta respuesta?
https://www.youtube.com/watch?v=9ikr4Xo6...
Thats for a 2000 Dakota but they should be exactly the same and if they aren't this gives you a good idea where it is located.
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 26
Todo El Tiempo: 6,279
