Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Segunda generación del iPhone. Modelo A1241 / capacidad de 8 o 16 GB / carcasa trasera de plástico negro o blanco. Su reparación es más sencilla que la del primer iPhone. Requiere destornilladores, herramientas de apertura y ventosas.
Error 6 fix?
I've been trying to reinstall iOS 4.2.1 on my old 3G iPhone, but it throws back error 9 or 6 every time. I've already tried most of the common solutions. Can anybody offer any assistance? Thanks!
Update (06/17/2017)
I also forgot, it's stuck in DFU mode, and the iOS was corrupted when I got it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Try to flash with 3Utools
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
are you sure all the connections are fine? dock and cable I mean.
- de
Yes, and I was doing it wrong anyway. :) I downloaded the actual program, and it fails at 13% saying invalid serial number.
- de
This tool is very useful~ And about invaild serial number, you can try to enter your device to DFU mode and flash again.
- de
Your device is stuck on DFU, you can exit that with 3uTools.
Imagen
Puntuación 1
2 comentarios:
With the serial number issue, it refuses to flash. It's also stuck in a somewhat damaged DFU mode, so the only way I can get it to even begin the process is by cheating with iTunes and unplugging it once it reenters recovery mode. I'm honestly a little stumped on this.
- de
If serial number issue issue still exists, there may be hardware issue. You are suggested to get a repairman to check your device.
- de
Añadir tu respuesta
Nikola Wozniak estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 624
