Saltar al contenido principal
Unibody de aluminio de 13", procesador Core 2 Duo de 2.0 o 2.4 GHz.
Preguntas 574 Ver todo
Is Patriot Ignite SSD compatible with this A1278?
I had some trouble cloning my HDD to a Patriot Ignite 480GB SSD (PI480GS25SSDR) it simply doesn't boot when used in the hard drive bay. I can boot it from an external enclosure only when the original harddrive is in the internal bay. If I remove the original Harddrive it is unable to boot from the external alone. I am running Yosemite, which should have TRIM support (thought I doubt this is the problem)
I've tried a clone (using carbon copy cloner), a time machine restororation, a clean install of yosemitie, and mavericks(didn't work on my machine after the first reboot the system would freeze and not progress any further, I had to install onto an external drive from another mac and then move to my other computer)/ I even tried a clean install of snow leopard from the original CDs (thinking surely this should work) but again it was unable to complete the installation on my computer.
I did a verbose boot and one of the error messages I saw said "/etc/rc.local" not found (sorry I'm typing from memory) however I went to try and copy from my original HD to my SSD and didn't find the file on either system. I left it overnight to boot, and it did get a bit further but was unable to boot. Any help or suggestions are appreciated. If you need more info let me know.
I've since concluded the drive simply isn't compatible, but maybe there is something I am overlooking. I got the drive on sale for ~$100 dollars and it uses 3D nand so I surmised is a fairly modern drive and should be of good quality as no cheap brand would use 3D printed gates
Update (06/06/2017)
Thanks for the tips. I did format using a guid partition scheme when I did my 3 clean installs (10.6, Yosemite and mavericks). However they still won't boot. They never even finish installing completely
Also CCC does copy the recovery partition properly just FYI I've never had any issues before except with this specific SSD
I will contact patriot though, that never even crossed my mind, thanks for that
Es esta una buena pregunta?
Puntuación 0
1 comentario
The version of CCC is a factor on it being able to re-build the hidden partition, the older version doesn't.
Even the newest version still has issues (all versions do) -Sorry ;-{
When you have a drive thats not well it can over stress it and if the SATA cable is on the weak side it can corrupt the image. As I deal with systems that run the gamut of health I can't always guess which ones are healthy enough that it won't make a mess. I should also add the corruption may not show up until the file is accessed.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Maybe I missed it but did you format the drive GUID and Mac OS X extended before installing the system. An external drive does not have to be GUID to boot from but the internal drive does.
I also no longer use cloning software because the repair partition does not get installed doing it that way.
Fue útil esta respuesta?
Puntuación 2
From what you describe I'm not sure if you formatted the SSD correctly. Instead of using CCC how about just installing the Mac OS as one would normally do using the OS installer. Then see if the drive works that way. If that fails then the drive may not be compatible. I don't use cloning software as I find it to fussy and often fails me.
If you review the specs for your system: MacBook 13" 2.4 GHz Core 2 Duo (Unibody) you'll see it only has a SATA II (3.0 Gb/s) HD SATA interface. Your SSD specs is listed as a dual SATA III (6.0 Gb/s) & SATAII (3.0 Gb/s) SSD Patriot Ignite.
So from the specs it should work. I would give Patriot a call or email to see what they have to say.
Update (06/07/2017)
If you did do clean OS install then its possible the SATA cable is not able to handle the higher throughput a SSD offers (over the slower HD). I would look at replacing the cable.
Follow this IFIXIT guide: MacBook Unibody Model A1278 Hard Drive Cable Replacement. Here's the replacement cable: MacBook Unibody (Model No. A1278) Hard Drive Cable - Apple P/N 922-8623.
Imagen de MacBook Unibody (A1278) Hard Drive Cable
Producto
$24.99
Puntuación 2
Añadir tu respuesta
Andrew estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 384
