Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La cubierta de la Guía de reparación de Mercedes W115 tiene ambos modelos w114 / w115 de 200 / 200D, 220 / 220D, 230.4 / 230.6 / 240D, 250,280,300D y varias otras variantes Estates, Coupes, Sedans de 1968 a 1976.
replacing driver side check strap
I need to replace the door check strap in my 76 300d W115. Took door panel off, but you can't get the check strap out without taking the entire window assembly out, it appears to me.
am I missing something on replaceing, and what is the proper procedure to removing the window etc.
need some advice on this.
thanks
Philip
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
@yadkin2002, Philip, I do not believe/not positive the entire window should have to come out to change the door strap, you should have to remove the pin and bolts and may have to turn(manipulate) the old strap to remove from door cavity or possibly have to loosen front window guide/track. Just to add a little to OT post, the video links(not your exact model) but may help in the removal of check strap. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=m3_NggBa...
https://www.youtube.com/watch?v=R0U3VNbb...
https://mercedessource.com/store/mercede...
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Philip estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 594
