How to replace the battery?
I have Yotophone purchased in UAE and the battery after charging drains out. How can I change the battery? appreciate receiving your reply per return.
Es esta una buena pregunta?
hello_chandran, You may want to check the 1st and 2nd link below for concerns on battery draining before changing the battery. 3rd link, below is a disassembly video link that will show how to get inside Yota to enable changing of the battery. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://howtodothing.net/yotaphone-2-batt...
Fue útil esta respuesta?
Its easy.
Just need to remove the cover where the usb port is. Its easy , just glue , Remove the screws and with plastic tool remove the screen from edges. its easy, aa lot of videos in youtube. Dont worry, its not hard.
you are right, it's even much easier than shown in the videos
1) you need to remove the plastic cover off the usb port
2) lift off the back screen
3) unplug the 2 sockets of the back screen and remove the back screen
4) unplug the battery socket and remove the battery, which is glued, take care, gently
5) plug the socket of new battery and glue it by gently pushing it into its space
6) reinstall the back scren and the plasti usb cover
It was the first time i did something in a smartphone and it went smoothly all right
where can we buy a good quality original battery for YotaPhone 2?
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 29
Todo El Tiempo: 4,741
1 comentario
How fast does it drain? When did you get the phone?
- de Cameron
