Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Este teléfono inteligente LG Tribute se identifica por el número de modelo LS660. El dispositivo fue lanzado en octubre de 2014 y utiliza el sistema operativo Android.
Break invalid sim card
How can I break my Sim card for my LG tribute phone asked for a pin got the pin wrong now my Sim card says invalid need to fix ASAP how do i break the Sim card and restore it to its original format
Es esta una buena pregunta?
Puntuación 10
Agregar un comentario
3 Respuestas
Solución Elegida
You could restore the phone, that should do the trick....you'll lose all your data...
Turn on the phone by using the Power button.
Go to Settings and then to Backup & Reset.
Tap Factory data reset.
Choose Reset phone and select Erase everything.
Good job! The hard reset is done.
Fue útil esta respuesta?
Puntuación 6
1 comentario:
hi is someone can help me ?
my LG is appearing invalid sim card please i need a help
- de
Hello, this problem causes when sim card slot doesn't registered in Network, my advice is call your network administration for sim card registration.
Puntuación 2
3 comentarios:
You should register sim slot by that IMEI code in your network operator.
- de
how can i do that sir , cause am in Africa , Ghana
- de
i really want to use this phone please sir , help me
- de
Need help. Took sim card out and factory reset but now it won't read sim
Puntuación 0
Añadir tu respuesta
Lisa Cheney estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 19,696
