My Data won't work
My wifi works perfectly, but when I turn off my wifi and turn on the data connection my phone still says no internet connection, and yes I do have data. I need help BAD.
Es esta una buena pregunta?
Hi @dipblomatt ,
Can you send and receive MMS texts OK? (texts with pictures or videos)
If so, it proves that your mobile phone data connection is working OK. (MMS require the data connection to be enabled and working, SMS use a different protocol and don't require the data connection)
You may be having a problem with the browser app that you are using.
Here is a link that may be of some help
Fue útil esta respuesta?
just check your apn setting and make sure your using the correct apn of your network provider
I did double-check my network mode. I was in CDMA. I needed to be in LTE/CDMA.
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 6,144
1 comentario
Same problem
- de Jawoko Simon
