Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El modelo A1302 de Time Capsule es la segunda generación del enrutador inalámbrico y dispositivo de almacenamiento en red de Apple lanzado en marzo de 2009. La mayor parte de la información de estas guías de reparación y desmontaje también se aplica al modelo A1254 original.
Time Capsule powers on but wont boot.
Basically, i had a power outage and after I got power, the LED would flash green for like a second and then go out. I opened it up and found 2 caps that bloated so I replaced them. Now it will turn on, the fan spins for a little bit, there is an odd sound coming out of the power supply, and the HDD won't spins up. After a minute or so, the sound stops and there is just a blinking, orange LED on the front. Anyone have any ideas? If nothing else, can someone get me a pinout of the pins so i can power it with something else
@mayer @danj @oldturkey03 @lpfaff1
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
To solve this, I first opened it up and removed the power supply following this guide Apple Time Capsule Model A1302 Power Supply Replacement
I found 2 bloated (dead) caps on the board and replaced them, although I replaced them it still didnt work.
I just decided to use an old computer power supply to power it and as I didnt use the hard drive for anything, I just removed it and powered only the board.
The guide i found for the pinouts is here.
What are the power supply pinouts for the 500gb time capsule?
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Cameron estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 1,539
