Saltar al contenido principal
El Samsung Galaxy J2 es un teléfono inteligente Android que se lanzó en noviembre de 2016.
Preguntas 20 Ver todo
turn off safe mode
how to disable safe mode I'm already try all think but no work please replyme fast because I need some app
Es esta una buena pregunta?
Puntuación 8
Agregar un comentario
1 Respuesta
Solución Elegida
There are several ways to disable safe mode . Some phones you need to just shut off and reboot . Others need be rebooted from the android menu. Select boot normally . You can also try removing the battery. Then reinstall it and reboot. or you can also go to the android menu and select wipe cache partition. One of these should reset your phone to a normal boot. Hope this helps
Fue útil esta respuesta?
Puntuación 9
4 comentarios:
Safe mode off samsung j2
- de
Hi @ Rohit Chudasma,
As @jimfixer said to turn off safe mode on Samsung Galaxy J2:
Press and hold the Power key.
Tap Restart.
- de
Safe mode disable krne ka kya
- de
if the safe mode was locked with PIN code and didn't know the code
- de
Añadir tu respuesta
Rohit Mudgal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 20,178
