Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Este es un horno tostador de 4 rebanadas de acero inoxidable. El número de modelo se encuentra en la parte inferior del aparato. Tiene una sola altura de estante y una bandeja de migas extraíble.
Toast dial timer is stalling
The bottom dial ( the toaster timer) keeps stalling and won't turn off. It ticks for a while but stops after a while. The at times works if the toaster is upside down or it's back.
Do you need to change the switch? Or is there another way to fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
Happened to me too. It's a potential fire hazard when the mechanical timer doesnt shut off the oven.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Alfred,
I suspect you'll probably end up having to replace the timer, but you could try cleaning it. I would imagine there's a fair chance it may be gummed up with oils, carbon and all kinds of other volatiles from cooking.
Get yourself a can of electrical parts cleaner and spray the heck out of the timer. The cleaner will evaporate completely so there won't be an residue left in it when you hook it back up and try it. If there are any openings in the timer, use the red tube to direct the spray inside to wash it out.
Outside of disassembling the switch, which may or may not be possible, that would be my best suggestion.
Hope it helps; let us know how it goes!
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thoughtful info, and so fast. Thanks!
- de
Añadir tu respuesta
Alfred Assin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 40
Todo El Tiempo: 1,271
