Saltar al contenido principal
Modelo A1286. Lanzado en febrero de 2011 / 2.0, 2.2 o 2.3 GHz Procesador Intel Core i7 de cuatro núcleos
Preguntas 586 Ver todo
Will a 2012 logic board work into a 2011 model?
Hello, I have a MacBook Pro 2011 15'' i7 2.0ghz, 16GB (1600mhz) RAM, 1 HDD in caddy and 1 SSD.
The AMD GPU is broken, and I don't want to buy a new one of this model because, you know, AMD...
I was thinking if I buy this logic board: MacBook Pro 15" Unibody (Mid 2012) 2.3 GHz Logic Board
Will it fit into my Macbook? This way I get rid of the junk AMD GPU and get an upgrade of CPU, GPU and USB.
The two models looks to have the same size and ports, perhaps I only need to use another heat sink as the geForce can be a little different from the Radeon, but except for this the other things looks compatible.
Has someone already done this? Will it work? I don't want to expense $600 to discover xD.
Imagen de MacBook Pro 15" Unibody (Mid 2012) 2.3 GHz Logic Board
Producto
$349.99
Es esta una buena pregunta?
Puntuación 1
2 comentarios
I'm quite convinced it would fit without a problem, but I wouldn't bet 600Us on that..having logicboards codes would help.
- de
The models of both are A1286. Someone knows How can I check If the LCD cable is compatible?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
I hope we will be helped to understand more about the Lcd connector differences. From what I can see with a logic board of a 2.0 Quad i7 in my hands and the picture you linked in front of me, the are no differences whatsoever, in any of the connectors, Lcd too, which seems to me just a standard 40pin.
Although personally I never fitted a 2012 board into a 2011 machine I don't honestly see any good reason why it shouldn't be fitting. I hope someone will be able to confirm.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
The tang of the cable connector is a bit wider on the 2011 displays. Using a fine emery file you can shave off the ends very slightly it don't take much!
- de
@danj Just like with 13" A1278 2012 cable connectors, they look the same as with previous models but slightly different size. Good to know, thanks.
- de
I might be able to save you spending your money on replacing your logic board.
As it turns out more likely your problem is not the GPU at all but a bad tantalum capacitor! Both AMD & NVIDIA systems have this problem.
Sam nailed it here! Logic Board Failure due to Nvidia Graphics processor GT330M
If you really want to make the jump I don't see why it wouldn't work. Sadly, I haven't tried it. But why don't you first see if you can get your system going for now.
Puntuación 1
5 comentarios:
lcd connectors are different
- de
The i7 2.0Ghz should be a quadcore cpu mounting a radeon 6490M. Does this configuration too have a problem with the infamous tantalum capacitors ?
- de
Apple uses the same basic design across the last three generations of Unibody MacBook Pro's. We had three boards in the back that were bad and after replacing the caps they work!
- de
I done a reflow in the GPU and this worked for about one week, but it's failing again.
But I think I don't have the equipment and the knowledge to do this capacitor replace.
- de
Thanks Dan, good to know !
- de
Añadir tu respuesta
Vinícius Ortiz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 2,245
