Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
LeapPad Ultra es una tableta educativa diseñada para niños de 4 a 9 años. Se lanzó en el verano de 2013 con un precio de venta sugerido de $99.
Half the screen is white with lines, other half ok. Not cracked.
Hi, Thanks for your quick response. Here are some images of the leappad.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
@ali1206 sounds like a bad LCD or a loose cable connection. Post some images of what your screen display with your question. If will allow us to see what you see. Use this guide for that. Worst case scenario you will have to open it up using this guide and check the cable connections to ensure it is properly seated. If so, consider replacing the LCD.
Imagen de iFixit
Guía
Agregar imágenes a una pregunta existente
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de LeapFrog LeapPad Ultra Repair Screen
Guía
LeapFrog LeapPad Ultra Repair Screen Replacement
Dificultad:
Moderado
20 minutes
Fue útil esta respuesta?
Puntuación 3
1 comentario:
@ali1206 bad LCD time to replace it.
- de
Is this worth trying to fix
Puntuación 0
1 comentario:
Actually yes it is, and I did, that was over 3 years ago. I bought a 2nd hand leap pad off ebay for a few quid, fixed the screen myself, which gave my son a few more years of use and learning with it. When he grew out of it I sold it on ebay together with the other one for parts. Result!
I enjoy a challenge, and isn't that the whole point of this website? To fix things?
- de
Añadir tu respuesta
Alison Shannon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 19
Todo El Tiempo: 2,501
