Saltar al contenido principal
LeapFrog LeapPad Ultra Repair Screen Replacement
Qué necesitas
  1. LeapFrog LeapPad Ultra Repair Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 2, imagen 1 de 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 4, imagen 1 de 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 5, imagen 1 de 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 6, imagen 1 de 2 LeapFrog LeapPad Ultra Repair Screen Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Screen Replacement, Motherboard: paso 7, imagen 1 de 3 LeapFrog LeapPad Ultra Repair Screen Replacement, Motherboard: paso 7, imagen 2 de 3 LeapFrog LeapPad Ultra Repair Screen Replacement, Motherboard: paso 7, imagen 3 de 3
    • Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
  8. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 8, imagen 1 de 1
    • Unscrew the five screws holding the motherboard into the housing.
  9. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 9, imagen 1 de 3 LeapFrog LeapPad Ultra Repair Screen Replacement: paso 9, imagen 2 de 3 LeapFrog LeapPad Ultra Repair Screen Replacement: paso 9, imagen 3 de 3
    • Lift the motherboard up exposing the fourth and final wire. Once you lift up the motherboard you will need to pull down on the wire to disconnect.
  10. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 10, imagen 1 de 1
    • Remove and replace motherboard.
  11. LeapFrog LeapPad Ultra Repair Screen Replacement, Screen: paso 11, imagen 1 de 2 LeapFrog LeapPad Ultra Repair Screen Replacement, Screen: paso 11, imagen 2 de 2
    • Remove the side grips simply pulling them both vertically exposing eight screws.
  12. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 12, imagen 1 de 1
    • Using the screwdriver with the PH1 bit, unscrew all nine of the exposed screws holding the plastic base down and remove the base.
  13. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 13, imagen 1 de 1
    • Using the screwdriver with the PH00 bit, unscrew the twelve screws holding the screen casing down.
  14. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 14, imagen 1 de 1
    • Separate the screen from the casing and circuit board.
  15. LeapFrog LeapPad Ultra Repair Screen Replacement: paso 15, imagen 1 de 1
    • Replace screen.
Conclusión
11 personas más completaron esta guía.
Rocky Hirsch
Miembro Desde 08/27/15
902 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 4-99, Meier Fall 2015 Miembro de USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
Miembros de 4
10 Guías creadas
8Guía Comentarios
I need a source for the LCD screen. Anyone have a connection?
rhilscher - Contestar
Where would i purchase the new screen?
gaildavies282 - Contestar
You cannot get the screens. I had to get one from a parted device. Best you could try for is finding one the correct size with the connector in the proper place that is 50 pin.
crhouk - Contestar
I bought mine on eBay for 15.00.
Joel Marcarelli - Contestar
Could you send the link to where you bought yours
Michelle Popoff -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 67
Todo El Tiempo: 15,790
