Reset to factory settings
When I reset my MiTravler back to factory settings it comes up all the time to input some codes ( numbers) in order to proceed, how to bypass and reset manually
Es esta una buena pregunta?
leroysimpkins, from pg.17 of MiTravler manual.
Restore default setting, if you want to reset the factory setting and erase all materials, please press,
Settings → Backup & Reset → Factory data reset.
Link to manual below. Good luck.
Fue útil esta respuesta?
what about the up/down key while pushing the on button
leroysimpkins, Yes you can try that it works on some devices, also note below,
From page #3 in your manual. Important Notice
-If the device is freezing or stuck, press the reset button(a small hole) or
long press power button for 7 seconds.
-When the performance is slow after using some applications, it is
recommended to close running application in setting menu.
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 18
Todo El Tiempo: 2,498
1 comentario
My mitraveler tablet is froze up need to reset it how do I do that
- de Richard martinez
