Why isn’t my Thinkpad charging?
The Thinkpad is properly plugged in at both ports but is not building a charge at all.
Es esta una buena pregunta?
Test the power cord with a multimeter like in this guide.
Probando la continuidad de un cable de corriente
Then I would also test the power adapter is it is working with the multimeter
If both test work fine then you know that your power adapter is fine and working.
You should also look at the power connector on he laptop so it is not loose because then the soldering might not lead the electricity. Good lock in testing.
Guía
Dificultad:
Muy fácil
1 - 5 minutes
Guía
Dificultad:
Fácil
5 minutes
Fue útil esta respuesta?
Try replacing the battery or buying a new charger.
Try pressing and holding down the power button for 3 - 4 seconds with the battery removed. Then try putting the battery back in, along with the AC adapter and see if it will charge. If this does not work try updating your motherboard.
If none of this works then try purchasing a new battery and AC adapter.
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 23
Todo El Tiempo: 358
1 comentario
student question
- de Jimfixer
