Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Una cámara digital diseñada y fabricada por Sony en 2012. Una cámara de 18.2 megapíxeles con Wi-Fi, GPS y una ranura para tarjetas de memoria.
Program Selection Wheel not working properly
Hi,
hope you can help: when I select a program it is often lost. For example: I set the wheel on P but on the screen the selection is - M. I have to move the wheel just a little bit to have the right program set again, but sometimes it's immediately lost again.
Maybe dust under the wheel? How can I clean it?
Thanks,
David
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Now the wheel works (even if ha become a little bit harder to roll), thanks!
Davide
- de
David, Glad to here it is working, pretty sure it will start easing up with usage after the cleaning. have a good day.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@catchtherainbow , David, Sony Cyber Shot, remove the battery, squirt a (little) 90% Isopropyl Alcohol under selection wheel and blow out/dry with canned compressed air. Repeat a couple time and this should clean out the dust/dirt from under wheel.
If this does not correct the issue button internal stops are probably worn and button assy. may need replace to correct. I will post a tear down guide if you wish to dig a little deeper into your device.
Sustitución de la carcasa externa de la Sony Cyber-shot DSC-HX20V
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
David estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 57
Todo El Tiempo: 1,721
