Compressor Cooling Fan stops
Refrig/Freezer has recent cooling fan...worked for 4 months then inverter went out and was replaced. At first unit would not start, but after being turned off for two days everything came on and worked for a week. Now the cooling fan isn't working and it no longer cools. An ideas why fan starts-works-then quits?
Es esta una buena pregunta?
How old is this machine? What is the model number? Who did the service on the machine?
- de mayer
It is from 2005. Model KSC525IN5500. Sears diagnosed both parts, which I replaced. I shut it off about 25 minutes ago-upon restarting the fan came on-it is probably cooling, but need more time to be sure.
- de Doug Pearson
It is cooling now. But, as noticed two days ago, it is cooling the freezer past the set point (currently at 0, while set for 6 degrees. I suspect it will fail again soon.
- de Doug Pearson
