Saltar al contenido principal
La plancha para pelo Fahrenheit FHT 125PRMR usa el calor para alisar el pelo entre dos placas de cerámica. El dispositivo puede ser usado para alisar, rizar o ondular el cabello.
Preguntas 3 Ver todo
Why is my fahrenheit flat iron not heating up?
One of the heating pads on my Fahrenheit Flat Iron is not heating up. I have plugged it in to several different outlets to make sure it wasn't the outlet that was causing the problem. How could I fix this problem without having to replace the whole unit?
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
4 Respuestas
Solución Elegida
Hello,
Using one of those working outlets, please take notice of whether on not the green and red LEDs are light when the device is powered on. If the lights are on when the device is powered on then the issue likely lies with the internal cabling or the heating pad. If the lights are not turned on when the device is powered on then the issue is likely with the power cable or the motherboard.
Please use the following link to properly troubleshoot any of the above issues.
Fahrenheit FHT 125PRMR Troubleshooting
Fue útil esta respuesta?
Puntuación 2
Respuesta Más Útil
plug it up and plug it out then just do the  keep doing it about 5 times
Puntuación 3
4 comentarios:
Omg thank you so much. My straightener would not heat up then I tried your method and it worked!
- de
I'm have a similar problem when I plug it in and turn on the temperature continues to go to 022f it won't get hot at all does anyone have any advice please ...thank you
- de
Hi i have a digital display for my temperature on a silver bullet fd200 and the temperature goes up but doesn't stay it goes back to 000°c. So i turn temperature up to 220°c then it flashes and goes back to 000°c. What could the problem be?
- de
This worked on the third time 😍👏🏾 thank you so much. I probably didn't need to throw out my hot comb this method could of worked 🥴
- de
here are few steps which i was tried and got my straightener fixed you can also try these to fix yours
Puntuación 0
T3 Hair Straightener Not Heating UP.
Here a few possible solutions that you should try to fix your T3 straightener.
  1. factory reset straightener
  2. ensure the screen is locked
  3. and straightener plugged correctly into power source
  4. check your power source working correctly
here you can read more details to fix T3.
Puntuación 0
Añadir tu respuesta
Joshua Potts estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 77
Ultimos 30 días: 352
Todo El Tiempo: 35,235
