Desplázate por este tema para encontrar el lugar apropiado para este comentario. Luego haz clic en "Añadir comentario a esta publicación" para moverlo.
4 comentarios:
do you see a light on the laptop usually orange or green it should be flashing or static ... this will tell you if the laptop is getting power
Hi, Try the following. Remove the charger from the laptop, then remove the battery. Press and hold the power button for 30 seconds then release the button. Reconnect the charger, ensure that it is switched on (leave the battery out at this stage) and try to start the laptop.
If the laptop starts normally, wait until the laptop has completely booted and reached the Windows desktop then shut down the laptop in the normal manner. Disconnect the power to the laptop, reinsert the battery, reconnect the charger (switch on the power to the charger) and try to start the laptop.
- de Reboot Gozo
no, nothing, thank you
- de JILL CAMPBELL
bought new power adapter and still nothing, could it be in the jack where you plug in the adapter
- de JILL CAMPBELL
- de jayeff
