How can I remove stripped screws on trackpad brackets?
Six 1.6 mm Phillips screws securing the trackpad to the upper case. The screw heads are stripped and I can't remove the brackets. These are tiny screws and I can't get any movement. The screws on the trackpad itself came out with no problems. The upper case are frozen solid.
Es esta una buena pregunta?
2 comentarios
could you add photo ?
- de Reboot Gozo
I got the screws out! I tried several of the methods described without success. One worked with a slight variation. I turned to an engraving tool since I lack a rotary tool. I used it to grind a slot into the screw heads and then an oversized screwdriver to turn them out.
As a result I've completed my trackpad replacement and am happily clicking away again,[image|889115][image|889116]
- de mjheider
