Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Acer Iconia A3 es una tablet Android 4.2 Jelly Bean de 10,1" con un procesador Mediatek de cuatro núcleos.
Tablet doesn't turn on
Acer iconia tablet a3-a10 doesn't turn on just a light flicker tried soft and hard reboots and no response
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
5 comentarios:
How many amps does it draw from the usb charger? Check with a multimeter by splitting either +power or -power and put the probes on the resulting 2 ends of wire.
- de
Ethan can you tell me about the solution to that problem? i have the same problem, and I need resolve it soon, Thank you
- de
Yea, as @David said check all the connections and reseat them. Does it get recognized by a PC?
- de
Hi guys same problem any way to fix it
- de
hi cliff
my tablet appears to be fully charged , but will not start up
I had to press hard, then harder still, It would now appear that the power switch has failed, is it difficult to replace it
Scott C
- de
Agregar un comentario
2 Respuestas
might be a LCD cable not plugged in all the way.
Fue útil esta respuesta?
Puntuación 0
'''it's too easy Guys .
-If you are unable to start the process for your tablet does not answer the Preloader mode, you need to remove the back cover and disconnect the battery and start the tutorial battery disconnected.
Once the tutorial finished, reconnect the battery. put in charge 10 min and then attempt to restart.
1- remove the back cover.
2- disconnect the battery.
3- reconnect the battery.
4- put in charge 10 min.
5- attempt to restart.
GOOD LUCK
[RYAN KHENNOUCI]
Puntuación 0
Añadir tu respuesta
Cliff Booth estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 2,103
