Saltar al contenido principal
Modelo A1181: procesador Core 2 Duo de 1.83, 2, 2.1, 2.13, 2.16, 2.2 o 2.4 GHz
Preguntas 1203 Ver todo
Not charging, Charger light Green
Hi guys!!
Got a Macbook (mid 2007 model) that will not charge. It works off the power cord but cant charge the battery.
I charged the battery in another macbook and it works fine and holds charge. I also tried a different magsafe power adapter and same thing.
When plugged it, light turns GREEN and stays lit but in Max OSX says "Not Charging".
Tried a SMC reset no luck..
Any advice what it could be? Im looking at the DC-IN port but anyway i can narrow it down to that specifically?
Some say to clean the connector port, any recommendations with what? Qtip and nail remover?
Thanks!
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
3 Respuestas
Solución Elegida
The most common on this is the magsafe board. Here's how to fix it: MacBook Core 2 Duo Magsafe Board Replacement
Here's the part: MacBook MagSafe DC-In Board
It could be the battery connector. This happens a lot if the book was set in liquid: MacBook Core 2 Duo Battery Connector Replacement
There are two versions so check before ordering. Here's the energy star one: MacBook Battery Connector/Sleep Sensor (Energy Star)
Imagen de MacBook MagSafe DC-In Board
Producto
$19.99
Imagen de MacBook Battery Connector/Sleep Sensor (Energy Star)
Producto
$17.99
Imagen de MacBook Core 2 Duo Magsafe Board
Guía
Dificultad:
Moderado
30 minutes - 2 hours
Imagen de MacBook Core 2 Duo Battery Connector
Guía
Dificultad:
Moderado
Fue útil esta respuesta?
Puntuación 1
So i just tried replacing both of those from my other macbook and i still get the "Not Charging" in the status bar.
Now im not quite sure what it could be or what it is.. It runs fine of the charger..
Puntuación 0
Im sad i did this one + Replacing MacBook Core 2 Duo Magsafe Board, try another charger and still the same symptoms :( wont charge and green light stay on. waste of time and money for my Macbook 2.4Ghz intel core 2 DUO White.
Any other solutions ?
Puntuación 0
Añadir tu respuesta
Jeepo23 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 4,176
