Saltar al contenido principal
MacBook Core 2 Duo Magsafe Board Replacement
Qué necesitas
  1. MacBook Core 2 Duo Magsafe Board Replacement, Battery: paso 1, imagen 1 de 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core 2 Duo Magsafe Board Replacement: paso 2, imagen 1 de 1
    • Lift the battery out of the computer.
  3. MacBook Core 2 Duo Magsafe Board Replacement, Memory Cover: paso 3, imagen 1 de 1
    • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
    • Using The Flexible Extension sold by iFixit will help with this step.
  4. MacBook Core 2 Duo Magsafe Board Replacement: paso 4, imagen 1 de 1
    • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
    • Lift the memory cover up and out of the computer.
  5. MacBook Core 2 Duo Magsafe Board Replacement, Upper Case: paso 5, imagen 1 de 1
    • Remove the following 3 screws:
    • One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
    • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle of the lower case.
  6. MacBook Core 2 Duo Magsafe Board Replacement: paso 6, imagen 1 de 1
    • Take extra caution with these screws as they can strip easily!
    • You could use a flexible extension to minimize stripping.
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
    • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
  7. MacBook Core 2 Duo Magsafe Board Replacement: paso 7, imagen 1 de 1
    • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
  8. MacBook Core 2 Duo Magsafe Board Replacement: paso 8, imagen 1 de 1
    • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
    • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
  9. MacBook Core 2 Duo Magsafe Board Replacement: paso 9, imagen 1 de 1
    • Remove the following 4 screws from the back of the computer:
    • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • During reassembly, the two longer screws go on the inside, and the two shorter screws go on the outside.
  10. MacBook Core 2 Duo Magsafe Board Replacement: paso 10, imagen 1 de 1
    • Remove the two Phillips screws from the optical drive (right) side of the computer:
    • Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • It is not necessary to remove the similar screws on the ports (left) side of the computer.
  11. MacBook Core 2 Duo Magsafe Board Replacement: paso 11, imagen 1 de 1
    • There's a trackpad and keyboard ribbon cable connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
    • The upper case is likely to stick at its connection above the front edge of the optical drive. If this happens, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening. Here again, inserting a plastic card, guitar pick, etc. can be useful.
    • If you stand the base of the MacBook on one end to get a better look, you may displace the four grey plastic clips that hold the right side of the upper case in place. Don't panic. They slide into slots at the top rightmost edge of the lower frame, above the front edge of the optical drive.
    • During reassembly, make sure the clips on the right side, above the optical drive, click firmly into place. They're different from the clips on the left side, and so normally they require a little firmer pressure to click into place.
  12. MacBook Core 2 Duo Magsafe Board Replacement: paso 12, imagen 1 de 3 MacBook Core 2 Duo Magsafe Board Replacement: paso 12, imagen 2 de 3 MacBook Core 2 Duo Magsafe Board Replacement: paso 12, imagen 3 de 3
    • While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
    • If there is no black tab, you can also use a spudger to gently pry the connector out of its socket on the logic board. This connector is tall, so be sure to pry straight up.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    • While you have the upper case removed, it's a good time to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
    • Upon reassembly, there are 4 grey plastic clips installed in slots running along the top of the frame in front of the optical drive (refer to second and third pictures). These clips must be installed in their slots for their mating tabs on the underside of the right side of the upper case to snap into them.
  13. MacBook Core 2 Duo Magsafe Board Replacement, Magsafe Board: paso 13, imagen 1 de 1
    • Remove the left 3 mm and right 8 mm (right screw is unnecessary to remove on some models)
    • One 3.25mm Phillips #000 (Head: 4mm dia. x .5mm thick)
    • One 8.5mm Phillips #000 (Head: 4mm dia. x .75mm thick
    • The Phillips screws securing the MagSafe board and the left speaker to the lower case. The next two speaker steps are unnecessary one some models as are steps 16 and 17 as the magsafe will drop in without removing these.
  14. MacBook Core 2 Duo Magsafe Board Replacement: paso 14, imagen 1 de 3 MacBook Core 2 Duo Magsafe Board Replacement: paso 14, imagen 2 de 3 MacBook Core 2 Duo Magsafe Board Replacement: paso 14, imagen 3 de 3
    • Gently de-route the speaker cable from the left I/O frame.
    • Use a spudger to lift the left speaker out of its housing. Grasp it with your fingers and move it out of the way.
    • Do not attempt to fully remove the speaker from the laptop, it is still attached the the logic board.
  15. MacBook Core 2 Duo Magsafe Board Replacement: paso 15, imagen 1 de 1
    • The MagSafe board connector is underneath the wires, be sure to pull on the connector itself pulling parallel to the socket.
    • Disconnect the MagSafe board connector from the logic board.
  16. MacBook Core 2 Duo Magsafe Board Replacement: paso 16, imagen 1 de 1
    • Remove the following three screws securing the left I/O frame:
    • Two 7.5 mm Phillips screws from the top and bottom end of the left I/O frame.
    • One 9 mm Phillips from the middle of the left I/O frame.
    • On some models, all three screws may be the same size.
    • If present, remove the black plastic spacer at the bottom of the left I/O frame.
  17. MacBook Core 2 Duo Magsafe Board Replacement: paso 17, imagen 1 de 1
    • Lift the left I/O frame up and out of the computer.
    • Pay attention to the thin metal EMI fingers, as they may catch as you remove the left I/O frame.
  18. MacBook Core 2 Duo Magsafe Board Replacement: paso 18, imagen 1 de 1
    • The MagSafe board is now free of all connections and can be detached freely from the logic board.
    • Using your fingers, pull out the MagSafe board.
Conclusión
136 personas más completaron esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
4 comentarios
Since the use of magnetic tipped drivers is probably NOT recommended, I'd keep some partially dried rubber cement or similar (snotty consistency) around to stick screws onto the driver tips. It makes guiding the screw into cramped areas much easier and rubs right off afterwards.
Eric Schlotzer - Contestar
I believe every single screw that I unscrewed required a Phillips #000 (instead of #0 or #00). Could just be my model. Great guide otherwise.
solarclathrate - Contestar
Following this guide, I fixed the balanced audio on my laptop. I appreciate your thorough instruction. My goal is to open a repair shop, but in order to do that, I must learn a lot from you. gartic phone
dietrichvid - Contestar
Bahçeşehir Konut Projeleri thanks for helpfull writing. this article very important and true.
Rouzman Dallin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 75
Todo El Tiempo: 111,172
