Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado en noviembre de 1998, identificado por el número de modelo HKT-3020.
Controller Port 1 doesent work
Hey Everyone,
I got a Dreamcast from Ebay, but the Controllerport A/1 doesent work. All the other, B/C/D works perfectly.
I hope you can help me
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Do you know how to solder? If you don't, your best bet will be to purchase a replacement controller board off ebay and simply swap out the part.
- de
yes i can solder, but why?
i read a lot of the problem on the internet, but that is always all controller prots, not only one. so i think the problme withe the fuse coulnd't be
- de
The reason I ask is that controller port board on the Dreamcast is among one of the more friendly parts for soldering, since all the components are through-hole. I would do a continuity test on the fuse, just to rule it out as a problem.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
This guide would be the easiest, if you don't want to solder it
Sustitución del puerto de mandos de la Sega Dreamcast
This guide would use a little more work, but you could individually change out one controller port
Also found this on eBay
https://www.google.com/aclk?sa=L&ai=DChc...
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
thunderblrd estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 24
Todo El Tiempo: 1,802
